Also need help to remove turn signal
There's a screw but else is holding the front turn signal?
Jonathan Michaud
93 Red RS
93 Red RS
Re: Also need help to remove turn signal
Should be two screws (I think.) Also you may have to angle it a little bit when you pull it out, since I think there's some sort of a tab behind it. Just wiggle it a little bit and you should find it. Don't pull so hard that you pull the wiring out though.
Taylor<P>1995 Chevy C1500 Dark Blue<BR>* 305 (5.0L V8)<BR>* Hypertech Performance chip<BR>* Dynomax dual exhaust<P>SOLD: 1995 Dodge Dakota Sport - Flame Red<BR>* 3.9L V6 - 175 hp<BR>* Flowmaster dual exhaust<P>I Miss my MX-3:<BR>1992 MX-3 GS Blaze Red
Sorry I just found out it was a simple ?hook? holding it<P>thanx anyway
Jonathan Michaud
93 Red RS
93 Red RS
