Okay I need a harness to install an aftermarket deck.
At my local CanadianTire they have harnesses for a lot of different makes and models BUT an MX-3.
There's one for: 323, Protege
Is this the right one?
Deck Harness
Re: Deck Harness
i think these should all work:
323 1990-1994
626 1990-2000
929 1990-1996
Miata 1990-2000
Millenia 1995-2000
MPV 1989-2004
MX3 1992-1996
MX6 1990-1997
Protege 1990-2000
RX7 1990-1997
323 1990-1994
626 1990-2000
929 1990-1996
Miata 1990-2000
Millenia 1995-2000
MPV 1989-2004
MX3 1992-1996
MX6 1990-1997
Protege 1990-2000
RX7 1990-1997
94 mx3 rs
92 mx3 gs curved neck klze SOLD
- Ryan
Re: Deck Harness
I would imagine most are universal... at least in function and pinouts.
Re: Deck Harness
Solder, and heatshrink are cheaper, and more compact. Give it a go if you're feeling adventurous. I started off with harnesses, then ended up splicing cause of imaptience and inability to find the right harness
It's not as hard as it seems, only real plus for harnesses is if you're planning on re-installing the factory deck for re-sale.
Re: Deck Harness
Scroll to bottom of page. http://www.aboutsecurityconcepts.com/Se ... sp?Cat=180" onclick="window.open(this.href);return false;
or this. for some reason this looks more like it. Comments anyone? http://www.mobilcaraudio.com/catalog/it ... 795490.htm" onclick="window.open(this.href);return false;
Re: Deck Harness
Second one says 01 and up, so I doubt it'd work. First one has two connectors? Is that right? I dunno, mine have been in a landfill somewhere since about 2002 I think.
Re: Deck Harness
Those are in my first link. They work ok do they?
