Chassis stiffening/reinforcement project
nightfire
Post by nightfire »
I'm going to take a shot at significantly stiffening my chassis by installing metal bars along the frame rails, with an X in between.
Does anyone have any experience doing this? I need an idea for clearing the exhaust... and I'm not sure exactly what to weld to. Any suggestions on steel thickness?
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
fowljesse
Re: Chassis stiffening/reinforcement project
Post by fowljesse »
Cjthor, and I were thinking about doing this. We were think more of welding in nuts, though.
onlytrueromeo
Post by onlytrueromeo »
Instead of just welding in nuts, you would either weld or bolt on metal to the frame rails themselves to support them first, then have x members go between the two pieces, like the miata braces. This will help our weak frame rails and prevent them from getting dented from jacks.
Flyer
Post by Flyer »
See those things on Flyin' Miata? Make those for the MX-3!
nightfire
Post by nightfire »
onlytrueromeo wrote:Instead of just welding in nuts, you would either weld or bolt on metal to the frame rails themselves to support them first, then have x members go between the two pieces, like the miata braces. This will help our weak frame rails and prevent them from getting dented from jacks.
I was thinking that, exactly. My frame rails are all chewed up as it is.
Is that the best place to weld a strip of metal? I was thinking something 6' long from wheel well to wheel well, on the inside of the frame rail. Maybe 1/4" thick by 5/8" tall. Then bolting or welding beams across in an X to each end, and possibly two more at each end horizontally across the car.
- Gord
tehbrookzorz
Post by tehbrookzorz »
If you guys go through with this, I want to see the results, and I hope you make diagrams with dimensions!
Cody
nightfire
Post by nightfire »
tehbrookzorz wrote:If you guys go through with this, I want to see the results, and I hope you make diagrams with dimensions!
Will do.
- Gord
ElectricEnergy
Post by ElectricEnergy »
Very interesting project! Keep us posted, I might try to put some thought into this also this spring.
KL-ZE Swap - OBX SS Headers - 2.5" Exhaust - Falken Azenis Tires - H&R Springs - ZX-2 Struts - CAI - Front & Rear Tower Bar - AWR Motor Mounts - 100hp wet shot (yet to be tested)
1/4" is pretty thick. I'd visit a few metal fab shops as they would have a better idea regarding material thickness vers weight. I though adding a roll cage to the inside was a good way to stiffen up a cars frame.
nightfire
Post by nightfire »
Well it's a daily driver.. Roll cage might be a little excessive. :p
Right now I'm thinking 1/4" square hot rolled steel angle beams (0.75" x 0.75") running inside of the rails, welded all along, and to the bottom. I'll weld 1/2" thick steel blocks to each end, and drill out holes to mount the X beams and horizontal beams. Then I'll find put a bolt in the middle of the X to tie the system together.
The X and horizontal beams could be aluminum for weight savings. They should experience mainly tensile force under loading if what I'm thinking about chassis dynamics is correct. Which it probably isn't. :)
- Gord
onlytrueromeo
Well, they wouldn't all be experiencing tensile forces otherwise your car would be trying to rip itself apart :lol:
One would be under tension, while the other is being compressed. The more "webbed" you make the design the better, as you will eliminate point loads. The miata one got it right - it distributes the load well and should not crack from use too soon.
nightfire
Post by nightfire »
onlytrueromeo wrote:Well, they wouldn't all be experiencing tensile forces otherwise your car would be trying to rip itself apart :lol:
Well imagine one corner of the car is compressed upwards over a bump. That should stretch the X beam from that corner to the opposite corner, as well as the horizontal beam on that corner, while trying to bend the frame rail. Lifting action on the front of the car should stretch the X, while trying to bend the frame rails. The only time they should experience compressive force is when jacking up the car, no?
- Gord
onlytrueromeo
Any time you "twist" a "frame" there will be tension, compression, and torsion.
nightfire
Post by nightfire »
onlytrueromeo wrote:Any time you "twist" a "frame" there will be tension, compression, and torsion.
On the frame, sure... but on the frame reinforcement? Where would the compression be, assuming you hit a bump with the front left wheel?
I know nothing about this stuff so help me get this right before I start welding. :)
- Gord
onlytrueromeo
I'm not very good at drawing, so bear with me. I will try to upload a sketch (in 2d) of what this would look like. I don't have my 3d modeling software on this computer.
