axels won't fit trans
matt-gerrard
Post by matt-gerrard »
I'm having problems with my 2.5 ze trans my stock 1.8 half shaft axels won't fit I've tried fitting it in short of breakin my gears and I've asked around and read the boards...... But still having problems
Thanks in advance matt-gerrard
I just love the cars that we have no matt-er(lol) how little or much you do to them there all so beautiful!Drive it, like you stole it!'92 gs V6
http://www.dfwmazdas.com/vbulletin/imag ... 1148070546
hgallegos915
Re: axels won't fit trans
Post by hgallegos915 »
where did that transmission came from?
you need special shafts that came with the tranny.. try mx6 shafts to see if the spline count adds uop and then have a shop make you a franken shaft. They can do it, well even you can.
-hec
You want the Lantis trans as thats the same exact car as the mx-3, what you dont want its a jspec LSD from an mx6 they are the ones that have the wrong axles. The Lantis and Astina are what you should be looking for LSD from, the Mx6 has longer axles so they wouldn't work, though you can use the mx6 axles you just have to take them to an axle shop and have them and combine the mx3 axles that fit into the hub with the ones that go into the tranny, as the splines are different but this will fix the length issue. Good luck trying to find spiral axels if it's the Jspec
matt-gerrard
The trans came from jdm engine corp in Dallas texas.
Return to “Transmissions”
