When i bought it, driving sensibly and slow 60mph tops, i got 300miles out of a tank, then with a few mods and doing normal driving i got 250miles to the tank.
Then now for some reason its dropped again. I have the probe header which has a O2 sensor port reading 2 cylinders, (where i originally had it) and another on further back where the 2 goes into 1, of the 4-2-1 exhaust. I though in my wisdom that putting the sensor there I would get a better reading as it would be all 4 cyl's. Seen no improvement though?
Another thing is its developed a 'power band', i have absolutely nothing between 2-3000rpm, then at 3000rpm it kicks me back in the seat. this was happening just before I swapped the sensor position. I thought I'd change the plugs 1st is this a good place to start? I have the Kerr Nelson Racing wires and they are pretty new about 9 months so i don't think its them.
Would an injector cleaning fuel additive do anything?
tell me what to do please!!
bad MPG and possible missfire??
1997 1.6 16v DOHC uk spec gs, 17" wolfrace triad, 2.0l probe s/s header magnaflow high flow cat, powerflow custom catback, CAI, zx2 struts w/ -40mm lesjofors springs
http://www.uk-mx3.com" onclick="window.open(this.href);return false;
