Even if you can't figure out how to run it off the stock module, there are aftermarket DRL modules you can buy with full instructions. Cheapest I've found is at Canadian Tire.
If I recall correctly the stock DRL underpowers the high beam filament in the 9004 bulbs.
tehbrookzorz wrote:If I recall correctly the stock DRL underpowers the high beam filament in the 9004 bulbs.
Ya, and HID no not like that at all!
If your really worried about DRL's, the LED's may do the trick, but you can also just use the low beams..i believe that's a trick some places use when getting a vehicle in from the US
1992 Mazda Mx-3 GSR - 2.5L KLZE : Award Winning Show Car & Race Car ['02-'09] (Retired) 2004 Mazda RX-8 GT - Renesis Wankel : LS3 Coils, BHR Mid-Pipe + Falken RT-615K 245/40r18 2011 Mazda Mazda2 GS - 1.5L Manual : Yozora Edition (1 of 500) 2003 Nissan Xterra SE - 4x4 Supercharged : 2" Body Lift, 4" Suspension Lift & 33" MTR Kevlar 2001 Nissan Frontier SE - The Frontrailer : Expedition/Off-Road Trailer Project
