Trans question
Posted: December 31st, 2008, 4:30 pm
by spidy53red
does anyone know what clutch i can use in the F-series tranny fit im turbocharging??
Re: Trans question
Posted: January 1st, 2009, 2:23 am
by Ryan
Any of the usual brands. Look through the FAQ's and they'll tell you what splines/diameters/sizes you can use on what trannies. I'm not nice enough to do that for you.
Oh, and your F series will explode on your driveway at the mere sight of a turbo.
Re: Trans question
Posted: January 1st, 2009, 3:23 am
by nos92mx3
Ryan wrote:Any of the usual brands. Look through the FAQ's and they'll tell you what splines/diameters/sizes you can use on what trannies. I'm not nice enough to do that for you.
False, mines holding up just fine. It all depends on how you drive it, obviously any major drive line shock will kill the tranny, but if you preload off the line, keep wheel hop to a minimum and dont always power shift. It should hold up to Some abuse.
Re: Trans question
Posted: January 3rd, 2009, 5:57 am
by spidy53red
Kool thanks
Re: Trans question
Posted: January 3rd, 2009, 4:34 pm
by spidy53red
Ok what about the 1.8 dohc BP from a 91 escort. is it a DBN or do i need alot to swap this motor? I found one w/ trans and ecu.
Re: Trans question
Posted: January 3rd, 2009, 4:58 pm
by Limegreen mx-3
sounds like ur an automatic
Re: Trans question
Posted: January 3rd, 2009, 8:43 pm
by Ryan
for a BP swap... from a SOHC, all I believe you need is the motor and ECU. run wires for VICS, and one to disty... this is all in the faq, why am I telling you.
