Fresh rebuilt BP-T with less than 15k miles on it.
miata tubular header
garret t3 turbo
38mm external wastegate dumped to atmosphere
2.5 inch catless turboback
apex-i n1 exhaust
hks bov
fmic/hardpipes
ported gtx intake manifold
bp55 ecu
apexi safc II
rx7 460cc injectors
msd 6al ignition box
msd blaster 3 coil
short shifter
poly bushings on sway bar, shifter, motor mounts
ground control coilovers
tokico s/r struts
v6 rear tie bar
gtx strut bar
rear strut bar
arp extended wheels studs
walbro 255 fuel pump
