Electrical problems from the brake pedal?
A section dedicated to Engine Mangement Systems & Engine Tuning. Megasquirt, SMS, Haltek, ect.
blaudust7
Post by blaudust7 »
When I step on the brakes at a stop my headlights blink once like a shortage and my rpms drop. When I step on the brakes when shifting to neutral or right after shifting to neutral the same problem occurs except this time the car almost dies with rpms dropping almost to 0. Is this the brake booster, master cylinder or something else? :? :?
shameem
Re: Electrical problems from the brake pedal?
Post by shameem »
Check your alternator, ground points/wires, battery terminals ....
Return to “Engine Electronics/Tuning”
