my dohc 1.5
Posted: November 29th, 2008, 11:32 am
by jon_young
rite guys you lot may have some gd sugestions, can i supercharge or turbo the 1.5 dohc,
and if i can is their any site s that sell the kits
Re: my dohc 1.5
Posted: December 1st, 2008, 1:21 pm
by aufgehdraht
from what i know about it you can. that's supposed to be a pretty beefy engine and would be able to handle it no problem. i would still rebuild it and put better internals in it though. you should be able to use eveything that a 1.6l engine uses for the turbo. I'm not for sure on it but everything should match right up.
Re: my dohc 1.5
Posted: December 1st, 2008, 2:27 pm
by jon_young
thats cool just need to find a kit now then
Re: my dohc 1.5
Posted: December 1st, 2008, 2:59 pm
by jon_young
so would the 323 turbo kit fit on with a few adjustments to teh oil feed and exhuast
Re: my dohc 1.5
Posted: December 1st, 2008, 4:23 pm
by Yoda
The B5 and B6 engines are identical in every way except for the shorter stroke of the crank and the connecting rod length. The blocks and heads can have the same castings depending on the model year.The only other difference but won't make any different as far as bolt on accessories it that the '97 -'98 B5 head flow better and have more aggressive cams
Any turbo manifold made for a B6 should be 100% compatible with B5
Re: my dohc 1.5
Posted: December 1st, 2008, 8:27 pm
by 10secSim
Hey did you buy this car from a guy in cornwall, ON. I'm from Cornwall and there was a guy selling a baby blue mx-3 just down the road from me with a b5 in it...let me know if it's you i can help you out with some stuff i'm starting a shop in cornwall on the side and know the mx-3s very well.
Re: my dohc 1.5
Posted: December 1st, 2008, 8:31 pm
by Savin
Jon is from the UK. He has an az-3 with the 1.5.
Re: my dohc 1.5
Posted: December 2nd, 2008, 1:10 pm
by jon_young
thank u for ur info, just what ineeded will be able to stat looking in to the turbo build soon
Re: my dohc 1.5
Posted: December 4th, 2008, 4:34 pm
by Yoda
jon_young wrote:thank u for ur info, just what ineeded will be able to stat looking in to the turbo build soon
If you are in the UK there is a guy over in Cork, Eire that has basically bolted the B6T turbo hardware to the B5 in his AZ-3 at Stock B6T boost levels he getting the same HP as a stock BPT. He was on the Yahoogroups MX-3 List back in the late 90's, don't think he ever joined MX-3.com
Re: my dohc 1.5
Posted: December 4th, 2008, 7:25 pm
by nos92mx3
Yoda wrote:The B5 and B6 engines are identical in every way except for the shorter stroke of the crank and the connecting rod length. The blocks and heads can have the same castings depending on the model year.The only other difference but won't make any different as far as bolt on accessories it that the '97 -'98 B5 head flow better and have more aggressive cams
You wouldnt happen to have the specs on those cams would you, yoda?
