My 92 GS with V-6 has a double relay behind the driver's headlight. It is about 3 inches behind the headlight and hangs down from the stock wiring harness. It has a rubber cover over it. It has two relays in it. Mine was full of mud and one is corroded. I see pictures in the manual but can't find a reference to what it is and what they power. Any ideas?
Thanks
V-6 double relay behind drivers headlight
- solo_ryder
Re: V-6 double relay behind drivers headlight
I *Think* they are fan relays.
Funny thing, when I was doing my swap and the car was not starting, I was hearing a very faint beeping noise from down there.. it was probably those relays so that is a mystery to me
