Aftermarket temp gauge question
jaythewolf1985
Post by jaythewolf1985 »
okay i got an aftermarket gauge pack and was able to hook up the oil pressure and volt gauge but can't seem to find a good place to put the temp probe? the to sencer holes are to small and i was wondering if the 1,6 had a drain plug/bolt in the block for coolent that i could use. any help is a great thanks.
