clutch problems
artman540
clutch problems
Post by artman540 »
my clutch pedal is on the floor. i replaced the slave and clutch master cylinder. bled the lines. its still on the floor. please help.
tom_finn
Re: clutch problems
Post by tom_finn »
bad clutch linkage, or possibly a leak?
tom
2fazed
Re: clutch problems
Post by 2fazed »
I can't remember the name of the part. It's the lever that the slave cylinder pushes that goes inside the tranny and moves that bearing bracket thing. If that's not in place, the lever will be loose, and thus your clutch. That's an easy thing to check, just reach inside over your radiator, or under your car and see if it's loose. If that's ok, I'd pump your clutch, and see if you can find any leaks(engine bay, calipers, etc).
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
