What throttle bodies you guys running?
Posted: October 7th, 2008, 12:56 pm
by cjthor
JWMotorsports is making me a custom intake and I am looking at what throttle body I might use. My output on the intercooler is 2.5 inches....I was thinking a 70mm mustang or something?
Re: What throttle bodies you guys running?
Posted: October 7th, 2008, 4:23 pm
by nos92mx3
I'm still rockin' the stock.
A 70mm mustang would be a good choice. you could also look into the upgraded throttle bodies from the ls1's and lt1's
Posted: October 7th, 2008, 4:55 pm
by cjthor
Aren't those oval?
Posted: October 8th, 2008, 7:47 am
by nos92mx3
http://cgi.ebay.com/ebaymotors/2004-PON ... 0305222620" onclick="window.open(this.href);return false;
Check that one out.
Posted: October 9th, 2008, 1:31 pm
by cjthor
That one has no TPS...but thanks!
Posted: October 11th, 2008, 2:41 pm
by cjthor
Ended up buying a 75MM mustang TB and found a TPS at a local auto supply for 36 bucks!
Posted: October 19th, 2008, 3:44 pm
by Limegreen mx-3
HUMM
there is on problem using the mustang TB
feather light gas pedal so when the time comes
GET use to it..
Posted: November 24th, 2008, 9:59 am
by Bo0sted_Rafi
Well, when you use a kia bp intake mani, you only needs to change the bolts pattern and the mustang 65-70mm will fit with any problems. In my case, i make a 1/2 spacer because in my intake mani, the pattern its rectangular. But its a good and efective mod to anyone who got a turbo engine
