manifold
- MazdaRider
manifold
would this fit my B6
http://cgi.ebay.com/ebaymotors/MAZDA-MX ... 0293025106" onclick="window.open(this.href);return false;
- RS_OBD'oh_2
Re: manifold
did you read the info or just look at the pic?
- MazdaRider
Re: manifold
just look
- RS_OBD'oh_2
Re: manifold
first or second line it says for BP... not a B6
- 10secSim
Re: manifold
I'm gona build a bunch of them for the b6 befor the end of 2009, if you want to wait...i'll make a group buy.
B6 1.6L DOHC, CAI, custom intake mani. with internal velocity stacks, 65mm thottle body, probe 4-2-1 header, custom 2.5" high flow exhaust, Centerforce dual friction, MS2, MSD 6A, Tokico struts, EIBACH springs.
http://www.cardomain.com/ride/2443642" onclick="window.open(this.href);return false;
- RS_OBD'oh_2
Re: manifold
there is a company that makes them for us already. What turbo flange would you make it for?
- MazdaRider
Re: manifold
how much
- 10secSim
Re: manifold
I've bin building a B6 turbo for a couple of years and got the engine all built and still waiting for it, but once i get it i'll drop it in the car...I still need to buy a turbo befor I build mine. Once I have the turbo and the engine then i'll know what angle it should have and make sure it clears the rad and the block. After mine is built hopfully by next summer i'll build a Jig to be able to produce them more efficiantly. They would be made with stainless 90 degree fittings and all TIG welded. I could weld the flange you want on it....but this wont be until next summer. for my back ground i was a pipe fitter for 5 years now i'm a NDT technition.
I rencently bought a house with a nice shop and would like to start building a lot of custom work like turbo manifolds and custom exhausts. I miss welding. Hopefully i'll be all set up by next summer. If you guys are intrested send me your e-mail and i'll keep it on a list for now. i'm not sure about a price yet, It depends how fency they look, I could make difrent styles of manifold if you send me a pic of what you want i could make it.
- RS_OBD'oh_2
Re: manifold
http://www.jgstools.com/turbo/index2.html" onclick="window.open(this.href);return false;
This log style might not be the most attractive mani's out there but they'll fit and support up to 600hp. $180 and whatever flange you want, can't beat that in my opinion.
- 10secSim
Re: manifold
I don't see the one for the B6. The one for the BP wont fit the B6
- RS_OBD'oh_2
Re: manifold
For best results please read left to right, top to bottom.10secSim wrote:I don't see the one for the B6. The one for the BP wont fit the B6
