I used the BF's injector harness on my BP (EGT) engine and the BF ECU runs it just fine. I had to splice in the IAC connector. I kept the stock EGT injectors. I tried some 280s but the BF ECU couldn't trim out enough fuel. I went back to stock which are 230cc I think.
Thought you guys might like to know.
My BP26 turbo and mani are on the way. I have an FIC ready to go but I'll wait untill the turbo is on. Actually... Maybe I should put in the bigger injectors and get it running n/a with the FIC's speed density setup -then- put the turbo on.
BF (B6 you guys call it) ECU will run a BP.
Re: BF (B6 you guys call it) ECU will run a BP.
Its known I just wouldnt recommend it if it is a 94 ECU with all the extra solenoids, you will run in limp mode more than likely.
B6 is the engine code and its on the ECU sticker, you do not have a BF.
All we need is B6 confusion.
The only thing I can see being a BF is the car classification perhaps, 323's were sometimes called BF's.Originally Posted by Gro Harlem :
B3: 88-89 carb Festiva models
B3-E: 89-93 EFI Festiva, 94-97 Aspire
B5: 82-84 GLC (might have been fuel injected..i'm not sure)
B6: 88-89 Tracer (some say this is carbed only, but again, i'm not sure, the power rating is 77 instead of 82 like on the 323's)
B6-E: 85-89 323, 90-94 323
B6-ME: 92-93 MX3 RS, 90-94 323 (cali)
B6-DE: 94-96 MX3 RS, 90-94 Capri
B6-ZE: 90-93 Miata
B6-ZET: 87-88 323 GT, 88-89 323 GTX, 90-94 Capri XR2
B8-ME: 90-94 Protege DX
BP-DE: 95-98 Protege ES, 94-97 Sephia
BP-ZE: 90-94 Protege LX, 91-96 Escort GT & LX-E, Mercury Tracer LTS, 94-97 Miata
BP-VE: 99+ Miata
![Image](http://i147.photobucket.com/albums/r298/mikefoo/bpt-small.jpg)
1994 MX-3 RS
Worklog: viewtopic.php?f=46&t=62251
B6 goodies for sale:
viewtopic.php?f=2&t=66333
2nd BP engine: http://www.clubprotege.com/forum/showthread.php?t=46695
- RS_OBD'oh_2
Ummmm. Get much more than 230's or 280's. The FIC does not have a 50% trim limitation like conventional piggys. I've got RX 460cc's on the way. If you try to boost on those little things you may have issues.
The block has BF cast into it and the bellhousing end is cast differently then the B6 I have sitting 10 feet from me.
- Ryan
BF is the code for the chassis. Clubprotege.com
I don't know for sure, but I think its some 323s and some proteges.... I don't really care, so I'm not going to find out.
As of today. No codes, no cel.
Idle is really low but so was the 1.6L.
Just to update:
Still running days later, daily driven, no CEL. I can feel o2 feedback sweeping so it's in closed loop. Turbo is here and I'll be installing some 440 injectors and the FIC soon. Finally no more airflow sensor.![Very Happy :D](./images/smilies/icon_biggrin.gif)
(I should put this in my build thread)
