So why are there 3 condenser fan relays?
Can someone explain to me how this works?
Re: So why are there 3 condenser fan relays?
afaik each fan has it's own relay and the 3rd turns them both on.
I mean there are 3 condenser fan relays on the passenger side cluster and there's 1 relay for the radiator/cooling fan on the driver side. Total of 4 relays. I don't understand what the 3 relays linked to the condenser fan do. I suppose one turns it on, maybe the other one makes it go faster or something... What's the 3rd one for?
Here are the circuit diagrams - it pretty much explains it all .....
http://img32.picoodle.com/data/img32/3/ ... 44adcb.gif" onclick="window.open(this.href);return false;
http://www.mx-3.com/manuals/showimg.php ... /Z-050.gif" onclick="window.open(this.href);return false;
http://www.mx-3.com/manuals/showimg.php ... /Z-052.gif" onclick="window.open(this.href);return false;
![Image](http://img517.imageshack.us/img517/5927/fliegetn0ss7.gif)
I already looked at them and the ECU diagram, and I don't understand. I'm not an electrical engineer. All I see is 3 relays powering the condenser fan, and I can't figure out how the system is meant to work, and which order do those relays get switched on and under what conditions.
Can anyone explain?
Can anyone explain?
