Clear Signal Lenses
Posted: August 25th, 2008, 5:01 pm
Hey guys,
Just ordered some clear turn signal lenses and sidemarkers for the front of my mazda from Corksport. As far as I know, and what I've read, I should just be able to do the sidemarkers by removing the screws and swapping the lenses. However as far as I understand, the turn signal lenses must be heated up, pryed off, and the new ones re-sealed.
2 Questions:
1) What is the common method of doing this, and does it require removal of the housings, an oven, etc, and what do you use to seal it?
2) Is there a way of doing this without removing the housings, i.e. a blowdrier and a flat-head screwdriver, and maybe some clear silicon to reseal.
Thanks guys,
2 Questions:
Thanks guys,
