I have a broken red wire on the connector side of the knock sensor, It can not be resoldered because its way to close to the connector.
I got another one from the wreaker, but its a wire that splits from 1 to 2 wire.
anyone done it with success?
Knock Sensor
Re: Knock Sensor
one is ground the other goes to the ecu.
-hec
- JWMX3
Re: Knock Sensor
the ground is bare and wraps spiral around the power wire
Mine was damaged and I tried to repair it but couldnt get rid of the engine light..... so i had to replace the sensor
![Image](http://img40.imageshack.us/img40/7481/avatarmx.png)
