Civic headlight source
- slimmyslim1420
I was needing to know where you guys get you civic projectors? Also did they come with bulbs if not where did you get them?
1992 GS ZE swap 94 dash swap drilled and slotted rotors full ceramic pads CS SS clutch and brake lines KL-36 ecu zx-2 tokico struts eibach springs short shifter Tenzo exhaust Hi flow cat 2.5 in piping
Re: Civic headlight source
ebay... search for 01-03 civic projector... any h1 bulb will work for the high and low beams (2 separate bulbs)
