MX-3 and Miata
redmxlookin4turbo
MX-3 and Miata
Post by redmxlookin4turbo »
Ok so i was reading through the forums and i keep seeing that mx-3's use alot of miata parts i was wondering if the upper sway bars would be able to be used? can anyone shed some light on this for me?
Re: MX-3 and Miata
Post by wytbishop »
I would say almost definitely no. The Miata being a rear wheel drive car has different spindles and control arms in the front than the MX-3. I know that none of the struts and other stuff are interchangeable. I cannot image the sway bars would be.
redmxlookin4turbo
Re: MX-3 and Miata
thanks i was wondering cuz all the info i was reading basically said the lots of parts were interchangeable
Re: MX-3 and Miata
Not really, maybe a few motor parts on the 4cyl Mx-3's, and some common design elements interior and exterior since they were in production of the same time, but that's about it.
The Mx-3 is ~90% based off the 323/Protege Platform. The Miata is it's own which is why it does what it does so well.
redmxlookin4turbo
Re: MX-3 and Miata
good to know cuz i got alot of miata buddies in the drift scene and i would swoop some parts from them
hppwdn
Re: MX-3 and Miata
Post by hppwdn »
I've seen it posted a few times that we can use miata rotors. Also Miata wheels, but that's all I've seen that we can use.
Ryan
Re: MX-3 and Miata
Post by Ryan »
interior handles, the BP engine...
