Oil in the spark plug wires. Not on the spark plug tip
Juans_93_MX3
Post by Juans_93_MX3 »
Today I was just taking out the spark plug wires on my MX3 (k8 engine). And as I was taking them out I noticed quiet a good amount of oil on them. I didnt take out the plugs themselves though. The car does not burn oil so I highly doubt its the piston rings.
So I am guessing this is a sign of bad valve cover gaskets. Correct?
Because I noticed just a bit of smoke (burning oil) coming from the header right by the radiator. It was coming from around the valve cover.
I know its obviously the valve cover gaskets but I just want to make sure.
I want to delay my KLZE swap until 8 months later. Before I start my Summer semister in college next year. So yes, I am still a bit concerned about this K8 engine. Reason why i want to wait that long is because. For one, I want to be 100% sure that my KLZE passes emissions. Emissions for me is every October. Atleast if I wait till than I will have a long time to fix whatever needs to be fixed.
2008 Mazda 3
1993 MX3 GS
nightridergsr
Re: Oil in the spark plug wires. Not on the spark plug tip
Post by nightridergsr »
Yeah, sounds like valve covers. Had the same problem, replaced my front valve cover gasket, and it helped. I agree if there would be oil on tip of plugs, would be rings I think.
Juans_93_MX3
Damn they cost so much though. Ill just go to the junkyard and get some from there.
2008 Mazda 3
1993 MX3 GS
hgallegos915
Post by hgallegos915 »
No they dont.. I just bought some on ebay for like 15 dlrs plus ship. check ebay for probe gt gaskets.
-hec
Don't use used gaskets, your wasting your time. Remember to use silicone (automotive type) when you install the new gaskets and use a torque wrench on the bolts. 70in.lbs
solo_ryder
Post by solo_ryder »
Juans_93_MX3 wrote:Damn they cost so much though. Ill just go to the junkyard and get some from there.
Lol, that aint gonna work so well, dont be cheap and get new ones so the issue dont happen again
hgallegos915
Dunno how that can be considered expensive LOL
http://cgi.ebay.com/ebaymotors/MAZDA-62 ... enameZWDVW" onclick="window.open(this.href);return false;
-hec
coltfoet5
Post by coltfoet5 »
if yours are not cracked or split just clean them up. You can clean them in gasoline then water right after. Dry them off, put them in the valve cover and then put rtv sealant all the way around. Let it set for 5 minutes then put it on the motor, tighten it down and let it sit for a day. That will cost $4 or so for the rtv sealant. If that doesn't work then get new gaskets.... not from the junkyard.
Juans_93_MX3
hgallegos915 wrote:Dunno how that can be considered expensive LOL
I meant that at AutoZone they cost a left nut and your man hood
2008 Mazda 3
1993 MX3 GS
