I have an amp that was running some subs that I had. The subs were dual 4 ohms and I thought I wired them into single 2 ohm but they were actually wired into a single 8 ohm. The system stopped working and I couldn't figure out why, I have since sold the subs (thats how I found out they were 8 ohm-buyer was electrician and tested it). I was wondering if I messed up my amp and I don't know how to check it. None of the 4 fuses on the amp are blown. Google search only came back with physical appearances like the amp actually being burnt black. Is that the only way to test it?
edit: I forgot to add, the light on the amp comes on green.
How do you check amp to see if blown?
94 mx3 rs
92 mx3 gs curved neck klze SOLD
- Ryan
Re: How do you check amp to see if blown?
As far as I know, you should be fine. You were running an higher impedance than you thought, meaning your amp couldn't push as much power through it as it could at lower impedaces... if you had accidentally wired them together at 1 Ohm, then you would be screwed because it would be pushing close to infinite amperes ( which never happens, only in 0 Ohm appliations like superconducting), which would blow it.... all fuses are good, it should be good. Any decent amp will have protection from all kinds of abuses ![Smile :)](./images/smilies/icon_smile.gif)
Hook it up and plug something in....
I had my subs hooked up to the amp and it they weren't producing any sound. The subs themselves work perfect. I'll check to see if it was something with my wiring kit. Last time I checked the big fuse before the battery was good, remote wire was good (amp turned on), replaced the rca's already still didn't get any sound. I have a Power Acoustik LT/1920, do you know if It can operate under 8 ohms? Could that be the reason the subs weren't working?Ryan wrote:As far as I know, you should be fine. You were running an higher impedance than you thought, meaning your amp couldn't push as much power through it as it could at lower impedaces... if you had accidentally wired them together at 1 Ohm, then you would be screwed because it would be pushing close to infinite amperes ( which never happens, only in 0 Ohm appliations like superconducting), which would blow it.... all fuses are good, it should be good. Any decent amp will have protection from all kinds of abuses
94 mx3 rs
- Dali
change the fuses in the amp with new ones, plug it into a friends car if you know someone with a running system...run it. quickest way to check, if it runs good...if not then you know something is wrong. if its burnt you might be able to smell it. start here and post back.
1993 White gs klze.
Every Kicker amp I have ever owned when it blows the amp will cycle on and off repeatedly. If your not getting any sound check the RCA's and the RCA input on the amp they are kinda fragile with kicker.
- DimaK
man, ive had this happen to me when i was just putting stereo in my current car, i hooked eberythign up and there was 0 sound, with all brand new stuff, i say diconnect it all and connect it back together, grab a volt meter and see if there is power coming in and coming out where its sepose to be, your amp will not blow because the sub is wierded up wrong, the sub itself will.i learned it the hard way.i ran 12 in ch kenwood excelon at 1ohm without knowing it, when the amp is not one ohm stable, amp just kept going into protection mode, and the sub pooched, i dont think theres anythign wrong with your amp
- Ryan
Oh, I had an an issue like this. I had everything behind the deck pulled apart and suddenly it worked again. I have no idea what was wrong.
Ok just so where all on the same page. Electricity has 4 elements, electrons, neutrons, protons and homotrons. Just remember, it's the homotrons that blow fuses. ![Laughing :lol:](./images/smilies/icon_lol.gif)
- onlytrueromeo
I agree, change the fuses and check again. Also check all your connections, including the remote wire, grounds, rca. Alsomake sure the power is still connected at the battery and that the fuse there is not loose either.
