[WTB] Fidanza Clutch kit
Posted: August 2nd, 2008, 6:15 am
by xSocialx
Anyone got a slightly used one or new? Or even if anyone has some links I can get one for my 94' GS?
Thanks,
Re: [WTB] Fidanza Clutch kit
Posted: August 4th, 2008, 4:13 pm
by Mooneggs
http://www.rr-racing.com" onclick="window.open(this.href);return false;
I bought one of their packages with clutch + flywheel like 5 years ago but this was for my klze... I guess the k8 would use the same one??
Posted: August 4th, 2008, 4:43 pm
by onlytrueromeo
K8 ones should be the same. The difference is with the Probe/mx6 one you'll have more "bite" because it's bigger. If you're using it on a stock GS I wouldn't get anything over the CM stage 1 w/ fidanza flywheel. If you just want cheap clutch you can get an exedy stock one off ebay. Keep in mind that is HIGHLY recommended to get a new clutch if you're replacing the flywheel. If you plan to upgrade in the future, a CM Stage 1 will hold up to a ZE. It's all about proper break in periods.
Posted: August 4th, 2008, 9:06 pm
by xSocialx
Will an exedy clutch kit like this
http://cgi.ebay.com/ebaymotors/_Car-Tru ... m245.l1318" onclick="window.open(this.href);return false;
Will that work on a ZE aswell? I just have a stock K8 5spd
thanks,
Posted: August 4th, 2008, 10:00 pm
by onlytrueromeo
It will not work on a ZE and thats an exedy kit for the 1.6 - you have a 1.8 GS, so that won't work. If you want something that will work on both a ZE and K8, get a clutchmasters from rr-racing. Whatever you do, don't get a 1.6L clutch for the k8 or ze.
Posted: August 4th, 2008, 10:16 pm
by xSocialx
haha ok so I think I'm going to order one from rr-racing then get a better one once I do my swap
Posted: August 4th, 2008, 11:30 pm
by datmazdboi
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0244359801" onclick="window.open(this.href);return false;
i have one
Posted: August 5th, 2008, 6:11 pm
by xSocialx
thanks a lot for that link
Posted: August 6th, 2008, 12:03 am
by datmazdboi
yea thats mine i was goona do the swap then i decide not to
Posted: August 6th, 2008, 2:06 am
by escortluver19
ill be pulling my fidanza/CM stage 3 setup this week.Both have 10k miles on them.Throw me an offer, and we can talk.
Posted: August 6th, 2008, 2:53 am
by datmazdboi
this is my best offer
Posted: August 6th, 2008, 4:24 pm
by xSocialx
As for the stage 3 I appreciate the offer but I think stage 2 is best cause this will alsp be my DD car/
Posted: August 6th, 2008, 7:14 pm
by escortluver19
xSocialx wrote:As for the stage 3 I appreciate the offer but I think stage 2 is best cause this will alsp be my DD car/
the stage 3 is still a full face disk with stock peddle feel, but i see what your saying.I never pushed the clutch either, but i wanted to go overkill incase i decided to boost or spray.
Posted: August 7th, 2008, 9:36 pm
by xSocialx
yea well I appreciate the help, but I don't think I'll be buying anything for a little bit considering I went and cashed a check for about 800 bucks, left my wallet in my truck for 2 minutes went to get it and it was stolen:) and it will never be found
