Grease Near Passenger Side Axle
Posted: August 1st, 2008, 10:16 pm
by *Y*
Hey guys,
I have a bunch of grease around the passenger side axle and I can't figure where it came from. I checked the boot and nothing seems to be ripped. Here is a picture of the situation. Any one have any idea?
Re: Grease Near Passenger Side Axle
Posted: August 1st, 2008, 11:58 pm
by Daninski
There's nothing else in that area that takes grease other than the CV or possibly the lower ball joint. Did you just have an oil change or something?
Posted: August 2nd, 2008, 2:43 am
by mazdamx3freak
x2 cv axle or ball joint.... also i would check the cv axle seal for tranny fluid leaking out.
Posted: August 2nd, 2008, 8:22 am
by MX3ak
definitely CV Boot
Posted: August 2nd, 2008, 1:21 pm
by *Y*
I'll check the ball joint too, but I don't think thats it as the grease is near the water pump as well. I thought I checked the boot very thoroughly but I'll check again. Is it possible for that much grease to leak through a tiny rip that hardly even detectable?
Posted: August 2nd, 2008, 3:09 pm
by hgallegos915
yup it looks like ball joint grease.
It probably has a pin sized hole.
