I have to clean off my shelves & have a lot of parts from my MX-3 and the part-out I did awhile back of the gold 92' GS
Here is the list:
Interior Parts:
2: O sh1t handle (mounts to roof above passenger door) w/screws & cap covers
Handle Pic $5
3: drivers-side black seatbelt in great condition. Leftover from when I removed my power seatbelts
Seatbelt Pic $10
4: Passenger & driver-side A pillar trim from NON POWER SEATBELT model. I never used them from when I did my seatbelt conversion
(no pic yet) $10
5: Headliner from non-power seatbelt model w/sunroof. I never put it in. Its tan in color & in great shape, non-smokers car, no burns/stains etc. Not sure if I can ship this & most likely going in trash
(no pic yet) Free if you pick it up!
6: passenger side door panel w/pw switch. In good shape, has the redish 92-93 fabric insert
Passenger Door Panel Pic $20
7: drivers door panel WITHOUT pw switch (don't ask!), in good shape too, w/redish 92-93 insert.
Driver Door Panel Pic $20
8: Single DIN factory bin that goes under the radio. snaps in place. black in color
DIN Bin Pic $8
Exterior Parts:
9: Drviers-side taillight in great shape, no chips,cracks etc.
(no pic yet) $10
10: passenger-side taillight in great shape, no chips cracks etc.
(no pic yet) $10
11: drivers-side front amber turn signal in great shape, no cracks/chips etc
Driver-side Turn Signal pic $5
12: passenger-side front amber turn signal in great shape, no cracks/chips etc
Pass-Side Turn Signal Pic $5
13: front bumper amber reflectors
(no pic) $5 (for pair)
14: drivers-side fender in great shape, from 92 GS, gold in color. Paint is in good shape, NO DINGS OR DENTS. no rust either. Has "GS" sticker emblem on it.
Driver-side Gold Fender Pic $40
Engine/Electrical Parts:
15: factory cruise-control vacuum module. Goes under hood & pulls the throttle cable w/vacuum from engine.
Cruise control Modulel Pic $10
16: air conditioning harness w/relays..tested & w tears/rips or corrosion
Air Conditioning Harness w/relays Pic $10
17: K8 ECU, i have two of these that work
(no pic yet) $25
18: JE50 factory K8 VAF/Airflow meter, works good
V6 JE50 Airflow Meter Pic $35
19: blinker/doorlock & other relays that mount above the pedals. They worked when removed
Doorlock/blinker relays Pic $5
20: factory fusebox w/fuses & cover, works fine
Fusebox w/cover Pic $10
21:Front valve cover w/ "Mazda" on it, for V6 engine
(no pic yet) $20
22: Automatic transmission for GS SOLD locally!
23: V6 / GS transmission bellhousing. I thought i cracked my bellhousing so I bought this,t urns out the fluid leak was from a crappy O-ring.
Transmission Bellhousing Pic $15
24: Reverse sensor for GS manual transmission. Comes w/a bit of wire for you to splice if needed. The wires on these are known to snap. I never replaced it before selling my car & this replacement has since been sitting in my garage.
Reverse Sensor Pic $10
25: Air Conditioning Condenser in great shape, no leaks. From a GS model, might also fit RS's but not sure.
AC Condenser Pic $20
26: GS / V6 Transmission Starter, works good, no serious rust/corrosion on the body.
Starter Pic $25
Payment / Shipping / Contact Info:
Prices do NOT include shipping. Let me know the part(s) you want & a zip/postal code and I'll get you the price shipped via paypal ASAP. The fender, door panels, transmission are obviously going to cost more to ship than the other stuff.
I accept paypal. My username is groharlem@hotmail.com" onclick="window.open(this.href);return false; which is a verified premier account w/over 400 transactions. I will take a money order but I need to know in advance that you are sending it.
If you want to contact me, PM is not the best way since my box tends to max out fast. AIM is better (GroHarlem6) or email me at groharlem@gmail.com" onclick="window.open(this.href);return false; which I check 2-5 times a day.
[FS] MX3 Engine/Electrical Interior & Exterior Parts
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Re: [FS] MX3 Engine/Electrical Interior & Exterior Parts
I call dibs on everything untill I see what your offering then I'll only take what I want, maybe.
I could use the reverse sensor let me know if u still have it, also if you can get me pics of the pedals I may take tjose as well
Teal 1993 MX3GSZE
OK so I was just trying to jump everyone to the head of the line. You've posted some very good posts, Props Gro. Dan
I still have all this stuff fyi.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
pm sent
not on aim
will email i guess
not on aim
will email i guess
1994 MX-3 1.6L B6DE 16v DOHC - rear disc swap, nix power steering/ac, Corksport f&r strut tower bars, Pedders urethane control arm bushings, urethane motor mounts, steel braided brake lines, painted dash, protege tranny
90 Miata w/ b6, Konig Lightspeed rims, Cams (boost to come soon)
74 Porsche 914 w/ 1.8L - restoration prooject
![Image](http://img.photobucket.com/albums/v454/glytcher/mx3%20stuff/ZOOMZOOM-1-1.jpg)
BUMP...i updated the list..all of these parts still available. I boxed most of them up this past weekend so they are all ready to ship asap.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
