Finally my parts came in...but they sent the wrong rods...there a little bit longer than stock!!
But other than that things seem to be in order. yay
We can rebuild her....
- XxantwawnxX
Re: We can rebuild her....
looks like you used importperformanceparts am I correct?
- XxantwawnxX
for everything : ), still need valvesprings.
