KLZE distributer on my K8 ????
Posted: July 3rd, 2008, 6:27 pm
by punkindrublic
can i use the distributer off my klze for my K8 ??
i fried my 1.8L V6 distributer !!!
any help would be great !!
i have a str8 neck ZE pulled from a probe !!!!!!
thanks For the Help
Re: KLZE distributer on my K8 ????
Posted: July 3rd, 2008, 6:30 pm
by punkindrublic
i just found the other post
HOW TO... klze disty on a k8
wow im slow !!
Posted: July 3rd, 2008, 6:35 pm
by punkindrublic
is that the only way to utilize a klze disty on my K8 ?
the thing is i have a ZE in my garage with the Hei Mod wires... but no ext coil !!!!
i just dont want to spend 300 on a used disty for my K8 !!!!!! which is currently in my mx...
any suggestions ????!!!!!!!!!!!!
Posted: July 3rd, 2008, 7:04 pm
by wytbishop
The ZE distributor is nothing more than a cap and a rotor so you must use an external coil.
Posted: July 3rd, 2008, 7:38 pm
by fowljesse
The metal part is exactly the same, except no coil?
Posted: July 3rd, 2008, 8:21 pm
by Daninski
Just in case you decide to buy a Disty, here's a link to a seller.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0213059694" onclick="window.open(this.href);return false;
Posted: July 3rd, 2008, 8:22 pm
by Daninski
I would suggest you sell me the ZE disty then go to Norhtern Performance on Parkdale ave and get another disty from them. Just a suggestion.
Posted: July 4th, 2008, 11:07 am
by wytbishop
fowljesse wrote:The metal part is exactly the same, except no coil?
The only thing in the metal portion of the ZE disty is the cam angle sensor. No coil and no ignitor.
Posted: July 4th, 2008, 5:20 pm
by punkindrublic
so my only shot is the hei mod !!??
Posted: July 4th, 2008, 11:45 pm
by wytbishop
The stock ZE in it's native chassis uses an external coil and igniter. Usually from what I've seen the coil and igniter are not sold with the ZE engines that are imported. I imagine it is possible to get them and use them, but they would not be easy to find.
The HEI mod is extremely easy and can be done for <$50.
Posted: July 5th, 2008, 10:25 pm
by Juans_93_MX3
Not to steal the thread but would a 1993 K8 disty work on a 1993 KLZE?
Posted: July 5th, 2008, 11:07 pm
by FlyVFR
Juans_93_MX3 wrote:Not to steal the thread but would a 1993 K8 disty work on a 1993 KLZE?
It depends on the wiring harness. If using a 93 MX-3 GS car harness, then I would say yes.
Posted: July 5th, 2008, 11:25 pm
by Nd4SpdSe
You can use whatever disty came with the car originally.
Posted: July 5th, 2008, 11:38 pm
by Daninski
I have what I believe to be a 93ish ZE and I have my 96 Disty on it.
