Best Intake?
Best Intake?
hey guys i was looking around for different intakes and i found the Weapon-r Polished Dragon Air Intake and the Weapon-r Secret Weapon Intake. which of the two is better? are there any other intakes that work good with the mx3? by the way i have the 1.8 v6. thanks guys, jim
93 GS SE - Raspberry metallic. K8 - 2 1/4in exhaust w/Magnaflow street series muffler, Custom intake, Kyb Gr2's w/Apex springs, Full kenwood audio - SOLD
Re: Best Intake?
none, all intakes are the same, spend 15 dollars on ebay pipes and go buy you a nice k&n filter, unless you like throwing away money
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- WhiteFinish
Re: Best Intake?
How do you guys think about olied and dry filters than?
K&N is an oid filter while you could get a dry one for just 20 bucks
- Mazdaspeed96743
Re: Best Intake?
I had an PRM cold air intake on my RS before and it was great.
Re: Best Intake?
typically oiled filters are reusable, the cheap 20 dollar ones are paper and you cant reuse them
Re: Best Intake?
That was a super burn!!!!zzzoomx3 wrote:you could always do the Stablo custom intake
<a href="http://www.fodey.com/generators/animate ... .asp"><img src="http://r3.fodey.com/117ef9486659942269d ... 7601.1.gif" border=0 width="404" height="110" alt="Ninja!"></a>
- fowljesse
Re: Best Intake?
Check out the FAQ, if you want to get the most out of it. IMO, the BEST intake is a short ram air. I'm working on one that has a hood scoop. In low rpms, it doesn't have to suck through a long tube, and in high rpms, the air is forced into it, like a super/ turbo charger.
- mitmaks
Re: Best Intake?
thats why subarus have their intake sitting right there on the top right under hood scoop. Best design imo.fowljesse wrote:Check out the FAQ, if you want to get the most out of it. IMO, the BEST intake is a short ram air. I'm working on one that has a hood scoop. In low rpms, it doesn't have to suck through a long tube, and in high rpms, the air is forced into it, like a super/ turbo charger.
