So Who Has Mx-3's That Aren't On The Road?
A Forum For Ontario MX-3 Club Related Topics.
Seems to be like it's a rough year for many of us, car related and not. I'm curious to know exactly who have Mx-3's that aren't on the road. For what I know:
Mine : More likely valvetrain issues. Doing a full rebuild + mods
Devlin : Down for the count
Fieromx3 : Fixing various small problems (for what I remember)
Mx3autozam : Minor motor issues and some interior work
Mx3 GSR For Dummies : ZE swap and exterior work I think.
I think there's more, seems like it anyway.
Sal
Re: So Who Has Mx-3's That Aren't On The Road?
Post by Sal »
hey guys,
well i just got mine back on the road from an accident which just this past winter. mechanicallly there were no damages and it runs great. that being said the exterior needs quite abit of work done to it, i'm hoping i can attend to that sometime this summer.
93 ZE curve neck, kl36 ecu, apex lowring springs tokico struts front and rear upper strut bars and a CAI.. still building!!
TREVO123
Post by TREVO123 »
Mines off the road again for like a year now, Not sure what im going to throw under the hood yet...
Just ZE'd my 96, back on the road as soon as I adjust the TPS and brakes.
EZ_4_FUN
Post by EZ_4_FUN »
My MS no longer primes the fuel pump just before cranking. Could be hardware issues or relays.
Currently trying to test different leads on the board to see where the problem is.
No luck thus far; its been about 3 weeks since I last drove it.
A turbo upgrade is in the works once I sort this gremlin out.
Will be modifying my current setup to fit a bigger turbo and possibly reroute the IC from a side mount to front mount.
I dont want to modify the X-member, so im simply going to reflange my current setup.
OSKY
95 MX-3 GS ZE Turbo: MSnS-extra, AEM WB, Blitz boost controller, MSD 6A w/ Blaster2 Coil, ZE disty, Redtops @ 550, Walbro 255, Garrett T3/T04E 60 Trim w/ .63 A/R, 38mm Deltagate Mark II @4psi, FMIC, Apexi BOV, CM Dual friction, 4-6.25 Kickers, 2ch Alpine V12. That's Alll.
http://www.pakfeifertuning.com
MX3_TURBO
Post by MX3_TURBO »
Mines also off the road right now, debating on if I'm going to make it road worthy again? Needs brakes front & rear, and wound up with a rusted leaking brake line in the rear that I never got around to fixing, and a sticky EGR valve which almost failed the last E-Test because of it. Body is starting to rust a bit now too, I guess it might be time to retire her @ ~280kms maybe part her out here or put it up for sale cheap in the KW area.... :(
-=MX3_TURBO=-
Rachelle
Post by Rachelle »
Mine isnt on the road yet, it didnt pass safety or e-test, but I dont care, buy the time im finished building it, it will hardly be street leigal if at all!!!
2010 Mazdaspeed 3
1993 Mazda MX-3
Like us on facebook at
http://www.facebook.com/davewoodmazdapage
Steve J-SPEC
Post by Steve J-SPEC »
One needs coil spring, rear calipers, air intake flex pipe...all new parts are sitting in the garage. One is in 100+ pieces waiting for next summer when the real fun with begin. Too many things to list...all good things.
'94 GS 5 speed-JDM K8, headers/custom exhaust, CAI, Tokico struts, Eibach Pro Kit, Moog strut mounts, custom solid engine mounts...
'96 GS 5 Speed air filter, KYB's
'94 GS 5 Speed OEM
fieromx3
Post by fieromx3 »
Rachelle wrote:Mine isnt on the road yet, it didnt pass safety or e-test, but I dont care, buy the time im finished building it, it will hardly be street leigal if at all!!!
details!!!
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
msd-supermx3
Post by msd-supermx3 »
ha ha nice topic lol my mx is still sitting in the garage (2 yrs now.) lol i feel bad. 3 weeks b4 i last drove it.
- just did a ZE swap
- having problems with it (post on a different topic)
- doing all rust repairs and body work (ill upload pics on my topic)
- interior is getting done as well.
- looking at a CAI or maybe a home made one (im broke) :crying:
- tune ups are needed (alot of it)
- new clutch is needed old one still good, but about to go.
thats all i could think of. lol
Good luck to everyone!!! with their problems and projects.
jschrauwen
Post by jschrauwen »
Mines been off the road for 1.5 years and I believe it's a sign that I should find it a new home.
MX3 GSR for dummies
Post by MX3 GSR for dummies »
Yeah, turned from car swap to engine swap to body kit swap to suspension swap to time consuming swap! I have now even pushed the boundry and doing up the lighting to the interior since a car that is half apart in your garage should still glow LOL. The car will be in storage in a nice warm spot and able to go for a run indoors while it patiently waits to be revealed it in the spring!
If at first you don't succeed....it never happened
94 mx3 GS w/ KLZE, KL31 ECU, clutchmaster stage 3, cross drilled rotors, Custom ram air intake, Custom exhaust, Toyo tires, 250LPH fuel pump, Modified Distributor, Upgraded Wiring etc, external HEI, Full Body Drift kit and freshly painted Grey. Interior neon accents and much more in progress
Andrew_Pakula
Post by Andrew_Pakula »
Mines in the scrap heap somewhere, lol
Rachelle
Post by Rachelle »
Mine is also off the road, and she has been since I got her, I have to use dealer plates if I need to take her somewhere!!!
But she is only not on the road because she is becoming a racecar, and there is a lot of work to do!!!!!!!!
2010 Mazdaspeed 3
1993 Mazda MX-3
Return to “Ontario MX-3 Club”
