Shifter Problems Someone help Please
Xiantez
Post by Xiantez »
I have a MX-3 1.6 liter MT 5 speed
I was driving one day and my entire shifter rod came disconnect from then center console mounting point. After falling further down then its normal position.... I pulled it back up into place and it sounded like it locked back in... after a couple hours of driving. The shifter came out of socket again. I keep having to pull my entire shifter back into its proper position.... I would like to know whats wrong, what parts i need to fix it... Any information would help
- Brandon
Thanks =)
tmac4t4
Re: Shifter Problems Someone help Please
Post by tmac4t4 »
maybe your cool shifter nob is loose and keeps moving up and down? im not sure really cant say that is a common problem, on any car for that matter
Ryan
Post by Ryan »
Peek at the underside, is the whole linkage falling through? I know its hard to look under these cars because they're so low.
Almost everyone I know has had their shift drop at some point. Common MX-3 problem isn't it. Dealer here in Canada said new part to fix is $65.00. The rubber mount just gave out.
Ryan
Post by Ryan »
Mine hasn't so far, and once it does, I'm hitting up the scrap yards :)
Ryan I think your a scrap yard junky, there is help but you have to take the first step. Acknowledging you have the problem is the first step to recovery. We're with Ya buddy.
Ryan
Post by Ryan »
Just so you know, I don't plan on going tomorrow... or the day after.... :confused2:
Okay, okay, I'm going both days!! but I need both the little flip up panels in the back, and the GS ties for the bottom suspension, and maybe a BP!
Now your trying to justify your dirty little habit. Actually I've gone a few times in the last few weeks. Got an extra OBD2 disty $50.00 and a KL02 vaf for $20 plus a bag full of interior parts. Felt like a kid in a candy store. Of course it was a very very necassary
Return to “Transmissions”
