Dissalbing the ABS system!! HELP!
Posted: June 15th, 2008, 10:50 pm
by colinsmx3
Anyone know how to Dissable the ABS system? I want to try something but my SE has ABS and I want to "unplug it" to check something. Anyone? I know there will be a light on the dash but that don't matter! :welder:
Re: Dissalbing the ABS system!! HELP!
Posted: June 15th, 2008, 10:57 pm
by solo_ryder
Take the sensors out on the front hubs and zap strap em to the strut, that is what I currently have setup as the hubs I swapped in are non abs hubs.. i still need to fix that..
Posted: June 16th, 2008, 1:27 pm
by shameem
There's an ABS & ABSPUMP fuse in the fusebox.....
Or you can unplug the connectors going to the ABS module (passenger side floorboard - close to center).
Posted: June 18th, 2008, 5:51 pm
by tmac4t4
do our cars even need abs?
Posted: June 18th, 2008, 5:54 pm
by solo_ryder
Yea, I have 4 wheel ABS in my 93 and front wheel in my 92 IIRC.
I think in the states it was a option and standard on canadian cars
Posted: June 19th, 2008, 4:13 am
by Whisper
tmac4t4 wrote:do our cars even need abs?
What's so special about our cars that they wouldn't need ABS?
ABS is a safety feature. Having it is safer than not having it, especially if you drive in the rain or snow a lot. The car would run fine without ABS, and some models do, but if you have the option to have it, I don't see why not.
Posted: June 19th, 2008, 7:28 am
by colinsmx3
Actually on Canadian cars they were an option aswell just on GS and SE models.
Posted: June 20th, 2008, 11:35 pm
by Nd4SpdSe
Hmm, you try pulling the fuse(s)?
The ABS module is under the passenger seat, could try unplugging that too
Posted: June 21st, 2008, 7:27 pm
by Ryan
Yeah my Canadian 93 RS definately does not have ABS. I have all the connectors for it, though, so it must have been an option...
Posted: June 21st, 2008, 7:36 pm
by tmac4t4
i know my 94 gs has ABS,,it must have been an option because my car is fully loaded with sunroof a/c everything, but leather :shrug:
Posted: June 21st, 2008, 8:43 pm
by hgallegos915
well my abs sensors died.. so it was either spend hundreds of dollars to diagnoze and repair the abs... ir simply iunplug the unit at the engine bay...
i dont knowwhat the hell was wrong with it.. it would make alot of noise when the car was SHUT OFF..
so i removed sensors, remoevd fuse and uplugged electrical power to the abs unit. Car feels the same. I guess because abs has never really worked in my car.
Posted: June 21st, 2008, 8:49 pm
by Ryan
When does ABS ever engage aside from on gravel or ice? I'd think you have zero ice in Texas.... Seems like a stupid option for coastal climates.
Posted: June 21st, 2008, 10:53 pm
by tmac4t4
if your speeding along at say 140 and slam on your brakes,,your gona pray they dont lock up otherwise ur gona spin out,,that where abs comes in
Posted: August 29th, 2008, 3:10 pm
by projectzemx3
yank the fuse.
