best klde ecu
A section dedicated to Engine Mangement Systems & Engine Tuning. Megasquirt, SMS, Haltek, ect.
studboy13
best klde ecu
Post by studboy13 »
ok, so im not sure if the ecu and vaf optimal options would be any different than the klze, just checking...
thank you
92' GS KLDE, Cosmo Racing UDP, CAI, AWR Motor mounts solid, Pheno spacers . interior gutted, MTX Swap, unorthodox racing flywheel/ 4 paddle clutch. short shifter, SRD bushings, brembo cross-drilled rotors, corksport racings red stainless steel lines. megan escort springs, zx2 sturts, whiteline rear sway bar, rear strut bar.
solo_ryder
Re: best klde ecu
Post by solo_ryder »
Well optimal ECU/VAF combo would be a kl01/kl07 ecu with kl02 VAF..
Basically any OBDI DE ecu and DE VAF will work fine. If you run a klze ecu you will most likely run rich and the VRIS points will be off.
96mx-3
Re: best klde ecu
Post by 96mx-3 »
if there any obdII ecu for a de? ..liek maybe a 626 or something...i looked in 97 probe..and there only 3 plug-ins for wireharness..any cars with 4?
solo_ryder
Re: best klde ecu
Yea, there is OBDII ecu's.. search around
Re: best klde ecu
Got my OBD2 p/n Disty from a 99 Probe GT. If I get a chance I'll see what the ECU has for plugs if thats what your asking for?
Re: best klde ecu
solo_ryder wrote:Well optimal ECU/VAF combo would be a kl01/kl07 ecu with kl02 VAF..
Actually for what I've been told, VRIS doesn't work at all ona DE ECU
I know my KL36 runs leaner than my Probinator and I've had no problem passing e-test with my KL36
96mx-3
Re: best klde ecu
Post by 96mx-3 »
yes please daninski.. i didnt no they made prode till 99 ..i thoguth it was 97..can u also get the number off it..on the white lable..thanks..
Return to “Engine Electronics/Tuning”
