Installing a oil and water temp pressure gauge!
A section dedicated to Engine Mangement Systems & Engine Tuning. Megasquirt, SMS, Haltek, ect.
Legato626
Post by Legato626 »
I am looking at adding a oil and water pressure gauge and would like to know if this is a hard task to take on. I heard i can just wire it into my ECU is that true?
1994 toyota supra single turbo
1994 Mazda MX-3 KL-ZE
If god owned a car... It would be a supra!!!
solo_ryder
Re: Installing a oiland water temp pressure gauge!
Post by solo_ryder »
Well it depends on the gauge. The water temp can usually be hooked up to the coolant temp sensor on the motor, or you can use a sleeve adapter and put it in your rad house. Not sure about oil temp. though
Return to “Engine Electronics/Tuning”
