Intermediate Shaft Removal Necessary?
Posted: May 18th, 2008, 9:13 pm
by bloodred
I'm just prepping to do a clutch change on my v6 presso.
Can I just confirm if the intermediate shaft first needs to be removed from the gearbox, before the gearbox can be removed from the engine, or if it can just be left in place and the gearbox slid on/off it?
I read a procedure for the ford probe which indicated that it could be left in place, I was wondering if the mx-3 is the same.
Cheers.
Re: Intermediate Shaft Removal Necessary?
Posted: May 21st, 2008, 9:11 am
by Smith18
Its 3 bolts and little tug, why not just take it out? its one less thing pulling on the transmission when splitting the transmission from the engine?
but on the other hand it shouldn't matter if you leave it in place just don't mess up the splines on it when putting the transmission back on the engine.
Posted: May 21st, 2008, 10:02 am
by ElectricEnergy
When I removed/reinstalled my transmission, I just unbolted the intermediate shaft from the block and left the splined end in the transmission the whole time. This also helps to make sure the spider gears don't fall.
Posted: May 21st, 2008, 8:18 pm
by bloodred
ElectricEnergy, thank you, that sounds like a good plan r.e. the spider gears. So i take it one just pops the inner CV off the intermediate shaft? is this just C-clipped on too?
Posted: May 22nd, 2008, 10:20 am
by ElectricEnergy
Yep, thats right, its held on the same way. It might fight you to the death getting it off though ;)
Posted: May 22nd, 2008, 11:44 am
by Daninski
Any info on a three bolt bearing replacement for the Imtermediate Shaft. I need to replace mine on a ZE.
Posted: May 22nd, 2008, 2:41 pm
by ElectricEnergy
I'm not 100% sure, but I don't know if you can even get the bearing on its own without the shaft. I just replaced the entire intermediate shaft on mine. Don't buy it new though, its like $350.
Posted: May 26th, 2008, 3:15 pm
by Daninski
Ok I got a bearing price, $65 bucks not bad. 93-94 are 3 bolt and after that are suppose to be 2 bolt.
