What Tires Fit the Stock 15" Rim?
Posted: May 16th, 2008, 9:15 am
I need to buy a set of tires in order to finally get my mazda on the road and I plan to put on a new set of rims (17's) in about a year or so, so I am trying to find some cheaper tires for now. However, I came across a set of 215 60-15's (BF Goodrich) tires and I wasn't sure if they would fit my OEM rims. The tires on there now are 205 55-15 and they are expensive! I checked tire rack and they offer a decent $70 tire but after shipping and mounting cost, it brings it up to what I would pay for a $90 tire installed here. I found a set on craigslist, as I mentioned earlier, that are 30 a tire (slightly used) but are the 215 60-15. They are a bit wider, which is okay with me (I personally think that 225 may be too wide) but the aspect ratio is 60, which is higher than the 55 and creates an overall difference of 16.25mm from that of the 205 55-15's.
My question is:
Will these fit without problems on my car?
If they do, will it enhance handling?
What other sizes would fit other than the OEM 205 55-15?
Any advice would be appreciated, thanks!
My question is:
