idle problem
idle problem
hey everyone i got a problem when my car is on and i drive it drives mint powerful everything but when i stop and idle it the rpm drop and the car turns off gotta keep my foot on the gas till i start moving any idea wut it could be i got a 1996 mx-3 v6 thanks everyone
Re: idle problem
Ill let you know before anyone else gets to ya. Learn to use the search function, and welcome to the forum.
But it sounds like you have a vacuum leak. Check the Air intake hose, make sure it doesn't have any cracks in it. Take it off very carefully, and check for holes. Or you could spray some wd-40 around it while its on, and check for your idle to jump. Double check all of your lines.
1992 Mx-3 GS. ATX to MTX swap. Integra short throw shifter, and CAI. HEI mod. Accell Canister. 3A racing muffler. Straight pipe.
