The car starts fine. Once its warmed up after a bit, it tends to want to stall out on me if I do not give it gas still and the clutch is engaged. For instance, if I am at a stop light and put the clutch in, the engine drops RPMs to about 0 and sometimes stalls, BUT sometimes it goes back to 1k Rpms and wavers up and down a bit. It only does it when its warmed up and when the clutch is engaged. What do you think??
I live in the US, and bought it for $600 with 117,000 miles on it. Runs ok except for that problem. Good buy??
![Confused2 :confused2:](./images/smilies/confused2.gif)
