Hi everyone,
New to this forum so really dont know how to go about the questions that I have, sorry if this topic is already covered.
OK, I have a 1993 mx-3 (australian 30x) - I dont know much about the car as I only recently got it. It's a K8 engine right..? My question is this: if I buy a KLZE V6 FF 24V engine will all the brackets fit or will I need to do them all over? Also will the shafts and the gear box be compatible with the KLZE engine, does the ECU need to be changed and will the air regulator still fit? (the electrical input size and shape is what im talking about) Or does everything have to be rewired? From what I hear..that's a pretty big job..
Thanks for any help..take care
KL-ZE and K8 Compatibility HELP
- se7en
Re: KL-ZE and K8 Compatibility HELP
okay, first off, most of what you have asked is covered here already, and is easily found if you use that search button on the top of the screen...
Anyways, with that covered I'll see if I can help with your questions anyway
1. yes, if it is a v6, it is the k8.
2. yes, the klze is a bolt in process. all brackets fit no prob. there will be one or two small changes,, like the coolant temp sensor or something...I don't know, you'll have to search this one out.
3. yes, the transmission and everything will bolt up perfect. same mounts etc.
4. the stock computer will have to be changed to the klze one, or millenia one, and the vaf air flow meter will work as is.
5. All wires will just hook up as per the k8.
6. Do the swap man, it is about the easiest engine upgrade swap out there.
Thanks heaps for helping out take care!
I still dont get WHY people dont swap out the k8 for a klde or a klze.. I just dont see WHY NOT.. really.. i get better gas mileage and more power.
-hec
