BPT GTR SWAP tranny help
Posted: April 23rd, 2008, 12:26 am
by Moe_maX
So I will be swaping a BPT GTR into my 94 DOHC MX3, I have a transmission question... I will be getting a G series tranny from a 91 protege lx as the many posts on this site state would be the best way to go... I was wondering... can i use the GTR stock flywheel (AWD) with the protege tranny (FWD)? or will i have to get a matching one out of the same year protege or a lighter aftermarket one? and.... is there really significant difference between a stage 1, Stage 2, Stage 3 clutch kits?
Cheers
Steve
Re: BPT GTR SWAP tranny help
Posted: April 23rd, 2008, 12:33 am
by TREVO123
Pretty sure you cant use the AWD flywheel as for its a different tranny.
Posted: April 23rd, 2008, 3:29 pm
by mazdachad
Yes you can use the awd flywheel if you use the awd clutch. Its what im using now for a year and grabs hard still using a used gtx clutch. If you use a pro lx clutch ull need a pro lx flywheel.
Posted: April 23rd, 2008, 5:51 pm
by Moe_maX
so... Let me get this straight... as long as i use the GTR Flywheel with the GTR Clutch it will work with the Protege LX FWD transmission?
Posted: April 25th, 2008, 6:57 pm
by Limegreen mx-3
get the slightly beefier KIA g-series tranny
I have broken 2-3 mazda g-series compared
to just 1 kia g-series trans.
Posted: April 25th, 2008, 8:56 pm
by mazdachad
assuming the gtr and gtx flywheel clutch is the same then yes you can im using the gtx as we speak
Posted: May 8th, 2008, 10:05 am
by projectmx
hey what are you doing with the AWD trans?
