After installing everything and buttening it all up i noticed a few problems... Please note that three electrical connections from the transaxle are hooked up as before.
1st problem: Automatic seat belt went foreward when i opened the door but did not return when i closed it, tried the passenger side and the same thing happened.
2nd problem: blinkers are not working at all, Checked all fuses and they are good.
3rd problem: speedometer does not work
I re-checked all conections and they are connected.
Are all these issues connected to one source?
Please help..... Thank you.
Help.... electrical issues after changing my clutch
92 MX-3 GS 1.8, looking for ZE.
Re: Help.... electrical issues after changing my clutch
Ok, Somehow the "meter" fuse under the dash blew when I put the battery in and it blew to where even when i pulled all the fuses and looked at them they looked fine but when i checked them all for continuity that one was bad. LOL
yeah I've had that problem before with fuses... It's hard to see that they are blown.
