#6 oil jet porting?
#6 oil jet porting?
since the #6 cylinder is very small compared to the others can i have it ported to match the jets (sprayers) i really dont want to spin another rod bearing just because poor oil flow... any ideas?
kevin
kevin
93 mx-3, hybrid de/ze-turbo P&P'd ZE heads,9.2:1 CR,garrett t3 57trim .60/.63,HKS SSQV bov, turbo xs 38mmW/G,24in downpipe,sts,13lbfw,sleeper FMIC,65mm TB,Walbro 255lph FP,F&R strut bars, ngk plugs/wires
p/s,a/c,cruise,vris delete..all go from here
- mx3autozam
Re: #6 oil jet porting?
Not really worth the time and money. Just use good quality oil and maintain your engine!
93 Mazda MX3 KLZE Turbo
- ElectricEnergy
I would assume that jet is narrower so that the oil flowing through it has a little more pressure. In this case I would trust the engineers who designed the motor.
![Image](http://i159.photobucket.com/albums/t148/electricenergy_album/caravatarcopy.jpg)
KL-ZE Swap - OBX SS Headers - 2.5" Exhaust - Falken Azenis Tires - H&R Springs - ZX-2 Struts - CAI - Front & Rear Tower Bar - AWR Motor Mounts - 100hp wet shot (yet to be tested)
k thanks it was just a question i'll be leaving it alone
- marcdh
Some probetalk guys shimmed their oil pump pressure release, so the oil has higher pressure all round. The 6th does apparently get a bit starved by comparison but sufficient and quality oil should see you right. Personally I haven't decided on whether to shim or not...
View Worklog
![Image](http://marcharrington.co.uk/banner2013.png)
View Worklog
- fowljesse
If you use the oil filter for the Corvette ZR1, I think it frees a little pressure, due to less restriction, so it's a little higher after it, especially if you use a good one like NAPA gold.
i have heard plenty about oil pump shimming...when i buy my new one i think i will shimm it but are the complete directions out there? i have searched and found nothing but pros and cons about it
- mx3autozam
I havn't really heard anything bad about it really. But some people including myself just don't like the idea of messing with that type of stuff. My engine is in my garage I just rebuilt it, I have been debating on this or not, after a few days researching it I have decided I am going to do it before I put the motor back in the car.
- fowljesse
Ask se7en about it, since he's a pro engine builder. I know it's common on Hotrods, but I've come to find some of those tricks don't translate.
