Neon Wiring Help
Posted: April 3rd, 2008, 1:12 pm
Hey you guys,
I've been running some 15" LEDs to light up the driver's and passenger's parts of the floor, had em installed, and hard-wired (well sort of) to my fuse box. And they have been working perfectly for the past few months, except they have 2 seperate switches, etc.
I recently bought 2 x 12" and 2 x 6" Neons that I would like to install now. Replacing the 15" LEDs with the 12" Neons, and mounting the 2 x 6" neons on the back/underside of the driver's and passenger's seats to have an ambient glow for those riding in the back seat as well.
Now the mounting of the lights is not an issue, I can take care of that. And they have the little cigarette lighter plugs that my LED's had, except the switches on these Neons are inside the plug part, and therefore, when i cut of the plugs, I lose my switch. This is also not really an issue because I want all four lights wired to a single switch, which i have already purchased, and installed into one of the unused switch positions on the center console (I believe they are for heated seats).
My problem as it stands is just the wiring. I think I know how to do it, but before I get carried away, I figured I might as well consult you guys just to make sure.
Okay:
The Switch is a black "Rocker Switch" which has 3 prongs on the bottom of it, one at the top, one at the bottom, and one in the middle. (This is what I really don't know how to wire, or if i should be using a toggle switch as opposed to a rocker switch)
I understand that I'm going to need some 12 gauge wire to run from my source to the switch, and then wire my 4 neons to the other side of the switch, but I don't know how exactly to wire the rocker switch.
Any help would be greatly appreciated...Wiring Diagrams welcome.
Thanks
Travis
Okay:
Thanks
Travis
