FS: Cold Air Intake w/ K&N Filter
Hey people clearing out the last few pieces of my deceased MX-3. It is a mandrel Bent Aluminum Cold Air Intake meant for a Teggy. Already cut set up to fit a MX-3 GS perfectly. Comes with couplings and even the vaf if you want it. It goes from the throttle body to the driver side fender well. Has a K&N Cone Filter which is a lil beat up but other than a few scratches and here in there is in excellent condition. I'm asking 40 shipped within the US. I also have a engine mount member left if anyone needs one. Here is a pic of it mounted on my old ZE. The first pipe is also tapped for the large vacuum line.
92 GS, 210 psi per cylinder KL-101 Engine, Pacesetter Exhaust, Centerforce DF, CAI, Hi Flow Cat, Headers.
By Spring 06: Megasquirt and FPR
By Fall 06: KL-31 Heads with Interprep Cams
Re: FS: Cold Air Intake w/ K&N Filter
Where'd you go? I've sent you PMs...
'93 GS, Curved neck KLZE, KL36 ECU, B&M STS, complete SRD shifter bushings, mx-6 clutch, ZX2 struts, Apex springs... and building...
- mitmaks
im interested in intake, can send you paypal.
