Question about BP swap harness
Umm anyone know and can direct me to a link, on how to go about taking out the wiring harness, preferably out of an escort, I have to go take mine out in a few days, and could use a step by step guide, any other info about the electrical part would be useful
- TREVO123
Re: Question about BP swap harness
just unplug the wires and unbolt the grounds and follow and unclip it from the firewall..
so it unclips right at the firewall, cause that would be hella easy, and Im guessing the wires from the firewall to ECU are the same for the BP and B6?
- umcamara
No, I think he means unfasten it from the firewall. I believe it goes through the firewall to the ecu, but still no big deal.
still you know any guides, what I think you guys mean is, unhook it from the ecu, then just pulls those wires from the ecu? like through the firewall, on the engine side of everything, also can I just swap the bp everything for the b6 everything and not have to splice stuff?
- atlantamx3
yes, it really is that easy. If you have a BP harness and ECU, take out the B6 stuff and put in the BP stuff and crank it up.
alright so no splicing if I rip out the old stuff and put in the new? haha sorry I sound so retarded just need to make sure
- umcamara
I'm not too sure if the harness inside the car needs to be changed at all though.
- umcamara
I'm very curious as to how this turns out, as I have a '96, and have a BP swap on my radar screen. If you can, start a worklog, or keep us posted.
