80a Main Fuse Blowing
Well i relocated my fuse box to where the original ecu was and ground the power cable to the spot where you bolt down the ecu, now everytime i put the + battery cable down it blows it. i have no pinches in the battery + that goes to the rear where i relocated the battery, anyone with idea???
- umcamara
Re: 80a Main Fuse Blowing
Uhhh....sorry if I'm misunderstanding you. But you're grounding the power cable? That would be your problem right there.
hahah no theres the negative and postive ground the negative.
