Not sure where to put this question, does the 4cyl and 6cyl have the same cat? Cause i found one on ebay for a 4cyl, but it says that it doesn't fit the 6.
I have a k8 with a stock cat that is clogged. Thanks.
Exhaust Question
Exhaust Question
1992 Mx-3 GS. ATX to MTX swap. Integra short throw shifter, and CAI. HEI mod. Accell Canister. 3A racing muffler. Straight pipe.
![Image](http://i321.photobucket.com/albums/nn376/exile84/DSCF3081-1.jpg)
![Image](http://i321.photobucket.com/albums/nn376/exile84/DSCF3084-1.jpg)
![Image](http://i321.photobucket.com/albums/nn376/exile84/DSCF3086-1.jpg)
- Kirk95gs
Re: Exhaust Question
it will not fit. If you put to small of cat on a exhaust it will restrict it and also make your engine run like .... well you know.
