water coolant pipe 92 AZ3 1.5 DOHC
Posted: March 6th, 2008, 11:48 am
Hi!
my jap mazda mx3 just broke down and i've been finding it very hard to find the part it needs. The car is a 1992 AZ3 1.5 DOHC and my mechanic said that the metal pipe connected to the back of the water pump is leaking due to corrosion. Does anybody no the proper name of this pipe or the part number or where to buy it? Would i be able to use the same metal pipe from a 1.8 mx3?
Any help would be greatly appreciated!!!!
Description from mechanic:
coolant pipe from the back of the water pump running across the front of the block under the exhaust manifold
Diameter = roughly 1cm
