Rear Disc Conversion?
JeremyP
Post by JeremyP »
rear disc conversion....was at some autowreckers and saw alot of GS V6's with the rear disc.....givin the amount of mx-3s there that all had rear discs...how hard would the conversion on a 94 be?...whats involved...how long does it take?...and what parts would i need?
94' KF-ZE, 2 Tone black and gray, Projectors and altezzas ( black ), CAI, moulded mazdaspeed mini sides. Raised spoiler.
lost_mx3
Re: Rear Disc Conversion?
Post by lost_mx3 »
Quoted from monty73741 & found in the FAQ http://www.mx-3.com/phpBB3/viewforum.php?f=24" onclick="window.open(this.href);return false;
Rear Disc Brakes:
It would be possible to swap to the disc brake from a GS in place of the drums on RS. You will need the complete rear spindle assembly, wheel bearing assembly, rear calipers, rotors, flexible brake lines and park brake cable. In addition you will also need the bigger bore master brake cylinder and front because four wheel disc brakes requires more fluid pressure and volume to operate rear calipers than it does to operate drum brakes. Unless you are racing on a tight circuit course where you are on the brakes often there is little advantage to swapping to discs. The disc brake assembly add a lot of additional unsprung weight and do require much more maintenance as the park brake actuator level has a tendency to stick in the engaged position.
1995 MX-3 1.6 DOHC 5SP.
