Troubles with the moonroof
Posted: February 24th, 2008, 9:41 pm
by MaX3
Help!! My moonroof is jamming up. Is this typical and what is the best trick to get them working smoothly?
Re: Troubles with the moonroof
Posted: February 25th, 2008, 10:41 pm
by MaX3
Nobody else has had this problem? Dang! I am not sure if I just have to regrease everything in the track or what.. its just making some nasty grinding noises and is not moving properly.
Posted: February 26th, 2008, 5:14 am
by Steve_SK
There are two metal pieces in mechanism which should be pushed to sunroof tracks and it will be ok, I had the same problem, pushed the button and only "rrrrrrrrrrr" noise was coming out and roof was not moving. Now it works fine.
Posted: February 26th, 2008, 6:18 am
by Kirk95gs
This is a very comon issue with the s/r.. there is a couple treads on what people have done/used to fix it. I lubricated every peice that I could get at with liquid wrench. then greased the rails. Now its back to new.
Posted: February 26th, 2008, 5:37 pm
by MaX3
Awesome thanks.. I guess the white lithium grease stuff is what I need to use?
Posted: February 26th, 2008, 5:49 pm
by Kirk95gs
Yeah should be good. I can't remember what I used.
